Maybe someone could do a test to check the contribution of the negative component* on the Rocket:
Headlights must be connected and ON for this test;
(you don't get a voltage drop unless the circuit is actually flowing current - when I explained this test on another forum, some members thought they had perfect system with no loss because they pulled connector off the lamp to measure the voltage!)
Measure voltage between the battery negative terminal and the terminal with the black wire at either/each of the 4-way sockets. On the Rocket this voltage would most likely be the same at both sockets.
Depending on that voltage drop, will determine whether or not a new large gauge negative wire needs to be run from battery.
On my S3, this was virtually a whole volt (0.995V) - with this kind of magnitude you can pick up a whole lot more lumens by eliminating that.
The difference between 13.0V and 14.0V at the lamp socket on an H4 bulb, goes from 1054 to 1356 Lumens!!!! That's almost 30%!
Even 0.5V loss - difference of 13.5V to 14.0V - is 1198 to 1356.
The contrary is, if it's negligible, you can simplify the upgrade further by just doing the Positive feeds (via the relays)
It may not be quite so bad on the Rocket, but let's get a measurement and see.
If it's less than 0.5V, some may be deem it not necessary, unless you want to squeeze every last lumen your voltage supply will give you!
If 0.5V or greater, there is a pretty good gain right there
* just backing up a bit to explain: There are three voltage drops in the round trip from the battery to the lamp socket and back;
Battery + to Lamp +;
Lamp + to Lamp -;
Lamp - to Battery -.
These three components additively equal the voltage at the battery.
The object is to maximize the voltage between Lamp + & Lamp -.
Higher Voltage means brighter, whiter light output.
For example, let's consider a 9006 low beam bulb rated 1000 lumens at 12.8 Volts and plug in different voltages:
10.5V : 510 lumens
11.0V : 597 lumens
11.5V : 695 lumens
12.0V : 803 lumens
12.5V : 923 lumens
12.8V : 1000 lumens ←Rated output voltage
13.0V : 1054 lumens
13.5V : 1198 lumens
14.0V : 1356 lumens ←Rated life voltage
14.5V : 1528 lumens
In simple terms - more volts make more lumens!
The relays and upgraded wire gauge virtually eliminate the contribution of the first component, Battery + to Lamp + and everyone pretty much readily understands that part.
(If you currently have stock set-up, you can measure from Battery + to Lamp + to see what your gain there will be, from upgrading wire gauge and relays on the positive)
But the return leg, from Lamp - to Battery - is almost as important and there may be some gain just from improving the 'ground' wire to the lamp sockets.
Many just assume 'ground is ground' but high current through small gauge wire can create a significant voltage drop and therefor the lamp -ve is not really at battery negative potential and so reduces the actual voltage across the filament.
Recognize you can very simply eliminate this component loss/ realize this gain, even without adding the relays, just by running new ground wire!
