papawoody
Standard Bore
I ride a 2008 Rocket III Touring with TORS replacement pipes. It’s a US bike that I imported into Canada from New Hampshire in 2001.
Last year, I took it into a Triumph Dealer in Stayner, Ontario and had the TORs installed as well as all of the 10K miles recommended maintenance including synchronizing the throttle bodies. It was hard to keep it steady when cruising at low speeds and the mechanic said that was normal for these bikes because the gears are “taller” on the Touring model.
After wintering in my garage, I siphoned out the old gas from and filled the tank with 91 octane fuel. It starts fine and idles smoothly, but when I’m cruising at 30-40 mph, it’s very jerky and hard to maintain an even throttle; it sounds rough and backfires frequently. I noticed this the first time that I took it out for an unplated and uninsured ride (couldn’t wait) after getting it shipped to my home in Canada.
The air filter is clean and I tried using some fuel injector cleaner but that made no difference.
Thinking that maybe the ECU needed a new map, I hooked up my cable and laptop and read the existing map (20368) which is the recommended OEM map on the Tune ECU web site. I downloaded the map anyway and can’t notice any difference.
Any suggestions on what to do next would be much appreciated, especially if anyone has had a similar experience. Thanks.
