Heated grips closeout!
Now upon further research I'm seeing the roadster kit as A9638014. And it's NOT that cheap. Must be more of the offloading of touring accessories. Good thing BB has free returns!
I just tried (last week) to order the heated grips subharness (A9930168 (SUB HARNESS, HEATED GRIPS)) and realy so I could plug in under the tank to wire my Oxfords, but was told the subharness is no longer available. Not a big deal, I can cut and splice, just thought it would be neat to plug into their connector since it was already there.
If I do use the T kit on my roadster, ilk sell you harness I don't use. But you'd still need the relay.
Upon some investigation, it appears the difference between the roadster and touring are the switch/switch housing, and wire harness. I've got T bars so I'm gonna have to use a different switch anyway and I already ordered the roadster harness for $14 bucks.
Dide if you have set already on the roadster then I wouldn't worry they are better then the T for some reason. I'll post when my 07 grips give out :)
I don't have either yet. I'm buying the T kit for the closeout price and the roadster harness to make them fit. The actual grips are the same part number for both.
I've had my ups and downs with these grips and have had no issues for the past 4 years... that said, thanks for the tip and I snagged a set; or I've at least attempted to.
-MIG
Yeah "attempt" being the key word. I finally heard back from BB. Both orders cancelled due to non-availability.
Write your reply...
