Heat from engine
I'd already given you a serious answer first up - post #2. Hopefully my balls will recover. :eek: Thanks Dennis for putting it so delicately. :p
yeah take that Richard your humor was a little to well disguised that time
The heat issue is worse if you are stilll running a Std Tune which are a bit on the Lean side for EPA reasons if you add a decel colum to the mapping or get a Dobeck (cheap alternitive) or a PCV+AT easily richen up the bottom end, if you are inclined you can get a TuneECU cable and you can either richen it up yourself or I or somebody else that knows there way around the software can help you
Oh and a Screen has little or no effect while moving in stop start traffic, when the engine is sitting in stop start traffic is when it is sitting in the lean area of the fuel map and there fore a lot more heat is generated from the exhaust:)
