slidderhd
Turbocharged
Are you actually getting power to the switch? I believe the wire colors according from my diagram are.... blue/black stripe (power in) and blue (power out). I believe the wiring is accessible in the headlight shell. There are two harness connectors in my headlight with a lot of wires....check those. Separate the connectors and reseat them. You can check for power in the wires as mentioned by using a very small needle/pin and poke it thru the wire insulation. Put the positive tester lead on the pin and the neg tester lead to ground. DON'T TOUCH the pin against the headlight shell or ground so as to create a short while testing. Just some suggestions.
Thanks for the info on wire color and pin. Hot wire to switch is blue. Return from switch is blue/black. Schematic says V for violet I guess. Power to light good. Power to relay good. Relay engaging good. No power out of relay to lamps. Opened relay and had corrosion on coil leads. Sanded contacts on coil and other contact points. Now works great.
