sonny
I have run Michelin commander's on my 2010 Fatboy (bought New) for the last 40,000 plus miles. (87,000 total miles) One of the best tires i have ever run on any bike. The Michelin Scorcher was designed for the V-rod and sporties 1200. Leans more toward a sport tire than the Commanders. May not get a lot of miles out of it but it should be a blast on the Rocket. Really do not give a #ats #ss if it says Harley on it. Matter of fact it should add to the entertainment when you blast pass them on their own equipment. Very soon my pipes from Paul should be showing up. Full system 3 into one. Believe you are running the same set up? Been reading the same and figured before the pipes show up might as well go for it and try the smaller front tire along with the Exedra Max. Have 28,000 on the Rocket X (bought new) and have already went through a set of Avon Cobras. The Avon's were standard size and did OK but at low speeds the front would shake a little. Cold weather they sucked. Went to the Darkside out of curiosity. Never had a problem with air pressure ran the tire around 31 PSI. Really liked the way the Darkside ran on the open rode but when it came to around town and rough roads it sucked. Running a Dunlap III up front and trusted it in tight corners but the car tire really made me nervous in a tight turn. I plan on upgrading the back shocks and springs up front at the same time (Ordered progressive springs and Wilber shocks). New to the Rocket and took some time to understand and read about all the different modifications that can been done. Cost effect verse fun factor should have a sweet set up.Any comments on why you went from the darkside? I didn't like that I had to air the tire every other day. With my body weight the sweet spot was 25 psi. It wasn't enough to keep the tire aired up tight against the lip of the wheel... I guess. It didn't have a hole in it.
I've been kicking the idea around about going with a smaller front tire next time. I've always ran the standard size. Been told the handling will improve with a smaller tire but the ride comfort will suffer. In the area I live the roads are curvy so I guess that would be a positive.
the Michelin commander in that size doesn't have harley wrote on it.
