Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,956
- Location
- Ride
I am not sure of your wiring diagram source. Have you read @barbagris and @DEcosse posts in various threads on Koso and Dakota instruments? Don't forget @idk has the manual and wiring diagram links for the pre ABS Rocket IIIs in his signature block too.I have just had another look and the signal wire from the ECU is a resistance of 5.5K Ohms - not sure if that changes with the fuel level because the tank is raised so the sender will be in a strange position. The Koso setup options for resistance are 100, 250, 500, 1200 and a custom setting of up 1999 Ohms - none of which are a close match in any way. The confusion continues![]()
