Free unrestricted maps for Rocket R GT and TFC now online
31248 is the OEM All Countries map for the GT, vin after AV5456. You can only get this in the app. Penner maps are only on the Tuneecu.net site in the custom 3/4 cylinder maps. Not available in the app. However, these are based on the US market tune. You need to copy the tables from this Penner tune into the stock 31248. I assume you raised the speed limit in the stock 31248 tune?
31248 is the OEM All Countries map forgg bethe GT, vin after AV5456. You can only get this in the app. These are on the Tuneecu.net site in the custom 3/4 cylinder maps. However, these are based on the US market tune. You need to copy the tables from this Penner tune into the stock 31248. I assume you raised the speed limit in the stock 31248 tune?
I didn't flash the stock . What is the point ?
this is my friend bike , my bike was Ander av5456 so I was able to flash an I did remove the speed limit
but I don't know how to transfer the tables
The basic guide tells you how to copy tables from one tune into another. Get the Penner tune for GT, AV5456 onto your tablet. Open OEM 32148 (assuming the bike is an All Countries bike). Do compare, using the Penner map. Go through the tables and where they are different, follow the instructions to copy the Penner table into the 31248 map. Or, since I just did this, PM me you email and I’ll send it to you.
T
Thanks so much!!!!
Ofer.mev@gmail.com
You need a Bluetooth module to remap. See the basic guide on Tuneecu.fr. In the bikes list, touch your model and a pop up tells you what to use.
OBDLink LX/MX, UCSI-2100 or vLinker MC
I carnt evern get basic conection via the tuine ecu lead . Wondering if it's because 23plate are differnert ecu
Not different. Are you trying to use a cable+adapter to connect your Android device to the OBDII connector on the bike? That won’t work.
Any one pm me regards
Yes was trying to use the cable . I'll order a Bluetooth. Thankyou very mutch ..
Obd lx bluettoth arrived as after remapping my bike .
Little confused which tuine ecu version I need before I buy a license so I can attempt conection. 2023
Didn’t you already try connecting with a cable? You can’t connect with anything until you purchase and register the app. Look at the instructions on tuneecu.fr. After you have done this, then connect to the app with BT and register the bike. Then you can load a map to your ecu.
