Which map file did you use? I have a 22 with the vin ending in av6738 and the 31019 map is saying it's incompatible. Is there not an unrestricted map available for this late of a vin?
The base map for the USA R with your vin is 31255. All of the tables are the same as the map for the older vins. The unrestricted map for the older vins is Rocket R USA Full Power 31019Map.hex. Have you tried to download this to your ecu? You have to unzip it first.
Yes, I downloaded 31019, unzipped it, and when I went to reprogram it says incompatible map. Am I missing something or is this map not compatible with later model year vin numbers?
Did you use the OEM list or the "custom" list? Both 31019. If you used the OEM then that may be why the error is ocurring, flashing the same map over itself
