Free unrestricted maps for Rocket R GT and TFC now online
OK, just got back after loading the DNK map to my bike. All I can say is holy smokes. This is an entirely different motorcycle with this tune. I have to think it has another 20 hp and 20 pound feet of torque I am unbelievably impressed with the tune of this bike the DNK tune gets my highest recommendation
Really though the “power under the curve” is the most amazing thing. The bike just had more power EVERYWHERE. Has to be the most amazing improvement per dollar I have ever experienced in this hobby. Just mind boggling how much different it feels. Trying not to be hyperbolic but it is breathtaking. Just the slightest hint of decel pop just enough to sound mean nothing like the ten pops per decel of old. One or two and very hushed. Why it’s not tuned like this from the factory is my question. I have the comp Werks exhaust so imagine the emissions are bad and illegal but it’s just so so glorious I hope the polar bears understand.
I bit the bullet and programmed the unrestricted map this morning. Went very smoothly and reprogrammed successfully the first time (with the headlight fuse pulled and a battery charger on).
Problem is now per the directions I'm supposed to go into the adjustments menu and reset adaptations. My menu doesn't have that option. It's supposed to be the first entry, but mine looks like this and only shows "throttle position sensor adjustment".
What am I doing wrong? I installed the TuneECU app from the web page and it's registered successfully.
Map open, ignition on, ecu connected? Have you gone into 3 vertical dots in upper right and changed themes under parameters to see if other adjustments show up? Does the adjustments button show up in the Dashboard screen? Has anyone else done reset adapt? This just resets the adaptations to factory defaults. After this, letting the engine run at idle for 15 min is supposed to adapt the idle to ambient temp and pressure. The ECU should do this after normal operation. I changed maps many times in the old Rocket without going through this.
Yes, map was open, ignition on, ecu connected. All was communicating normally, I just was getting the "Throttle Position Sensor Adjustment" instead of the "Reset Adaptations" option. I don't understand why. I started the bike and let the fans come on and then waited the 12 minutes more (was ~17 minutes) at idle without touching the throttle. Bike ran normally and no codes or errors were presented. Went for a ride and the bike runs awesome. The MUCH wider torque curve is amazing. No complaints, bike runs very smooth, just think it's odd why I don't see the reset adaptations option like others do (wish I would have looked for it before I reprogrammed, but I didn't).
Same here, "reset adaptation" does not appear on the menu. Just let the bike idle for 15 minutes. Adaptations will re-adjust during your riding anyway.
Yes I believe that the fast reset is not necessary just do the soft reset letting idle until fan comes on then 15m more then go ride and enjoy!
Don’t touch throttle. Start cold. Let set till fan goes on. Let idle for 15m more.
