First time Rocket owner looking for simple advice on oil changes
First off, thanks for the forum. Triumph doesn't exactly provide a wealth of knowledge in the Rocket "handbook".
I just purchased a 2011 Rocket 3 Touring with 4200 miles on it. I want to change the oil, but can't find any info regarding the filter / filter cover. Does this model have a chrome filter cover, or is that actually the filter? I ask because Amazon is offering a chrome filter, but also black filters.
Secondly, I notice the filter/cover has a hex nut molded into the body with a hole in it. What is the purpose of the hole? I don't want to damage the chrome filter/cover if there is a special tool or technique for removal.
Lastly, oil recommendations? I've seen threads that say use oil from the Triumph dealer, but the local Triumph mechanic (I don't go to the dealer) says he uses Rotella. I tbelieve him, as long as the specifications of the Rotella match the handbook.
I did watch a Youtube video on the oil change for an older model, so I know I need new washers and an o-ring.
Thanks in advance for the help!
Oil- Castrol, Power RS, Racing 4T, Full Synth 10W-40.
Filter- Mobil 1 Extended Performance M1-110.
This filter is a bit longer than the stock Triumphs but if you are gonna run the full 10K between oil changes it is better.
I have the same year and model Rocket as you have and the valve check is at 20k not 10k...
So I'm not crazy, right? The oil cap is just "press fit", it doesn't screw on/off? I've never seen such a thing.
Correct it is a press in fit.
Thank you! I know it sounded like a stupid question, but I've been changing the oil in cars, lawn mowers, and anything that takes oil for the last 33 years, and this is the first time I've seen a cap like this. Thanks for easing my mind.
I have always been taught and taught there is no such thing as a stupid question. Sometimes not asking is stupid. ;)
If it makes you feel better you can always twist it as you push it down. :)
bob
Write your reply...
