Finished my rear rack and panniers.
The racks are custom, built on the same mounting method as the Hepco & Becker panniers however I have modified these with the SW-Motech mounting hardware. To this I have mounted Burley Brand bags to round out the look.
@ExtremeAntics
I’m looking to do something similar. I wanted to confirm that I understand how you put this together.
Did you mount an SW-Motech SLC Side Carrier Construction Kit (loop) to a Hepco & Becker C-Bow mounting kit (SKU: 630.7606-MM)?
@ExtremeAntics
For my first draft this is what I did, then I had someone manufacture a complete bracket that looked better.
Very nice job and very nice setup. I was looking for a way to cleanup the mounts for my saddle bag. I got a single Triumph bobber bag from LaRosa and did a quick job of just some straight brackets to mount the bag and my rear camera. These brackets are just the ticket to clean that up and will give me the option to swap on a larger bag when I need to. Thanks for posting!
Should you consider fabricating another set of bespoke mounts for both the pannier and top luggage rack, I’d be excited to be your first customer! And I’m pretty sure you’d have a long order list in no time. 😎👍🏼👍🏼
Is the standard SLC system from SW-Motech
Sorry- it's not completely obvious.
So, if you order the brackets do they include the part that attaches directly to the bags? I would think that part only comes with their proprietary bags, yet you have them mounted to Burly Bags, so......
Are the "retaining cams" the receiving part that mounts on the bags? If so, great- then you can mount whatever bags you choose. This is what I've been looking for.
If not,
