Exhaust advice
O.K. Here's a helping hand for you.
I have a burnt out Rocket, a stock header and a pair of stock Roadster mufflers with mounting brackets.
What if I mount this all up, make you a tube to connect the R/H muffler directly to the header and send it too you.
No coating, just a piece of tube, no charge.
Send me your delivery address in a PM.
Here you go, just 3D print it and your done :D
Will be in the post Tuesday.
This will accept the stock seal.
You can probably sell just that pipe coated. Keep those dimensions handy. I my want to buy one of those eventually. Seeing the step down from your header to stock size has me thinking about a new single sided muffler setup.
This "slip on Silencer kit" will slide straight onto your Header Anthony. Leave the reducer out of your kit.
As will this Twin Muffler system slide straight onto the stock Header, or to the header that you have.
I really like the look of the black as it appears to be pointed up a little more than the chrome. I'd actually like it to be about another 1 inch or so higher at the tail. So the top of the can is just below the banjo on the caliper.
Beyond that, the spot where the taper ends about a third of the way back, it catches my eye and not in a good way. It's not ugly, just not my thing. I think if it were one taper to whole way back, with maybe the last 2-3 inches not tapered, I'd probably like it more. I just won't ask you to make a special one, not like it and you be out that time and money
