I recently put on a new Excedra Max 240-55-16 on the rear and have been experiencing ABS activating too frequently. A couple times I would be coming in hot and it kicked in when I should have been able to slow under normal braking and things got a little hairy. Also was using front and rear simultaneously and front saved me. Only seems to do it at high speeds. Any body experienced this?
April fools is past gone TBone. That, or you have a heavy right foot. Orrr you need to try a car tyre :whitstling:
I have Bridgestone exedra Max has both front and back and I love them never had an issue
Well after still experiencing this problem only after EMax was installed I took it back to stealership and they told me that because of the taller Emax in rear and smaller Michie Commander in front that is why the ABS is kicking in way too soon. It is only doing it on the rear so I'm gonna just pull the rear ABS fuse for now like I did on my Tiger so I could back it into the corners.
I think your dealership is full of it. Michelin 140 Scorcher and Emax rear throughout two sets of tires never had a issue with the ABS. Have someone else look at your bike.
Write your reply...
