So yesterday I tried taking advantage of what will likely be the last 70 degree day for months here in the Pacific Northwet by taking the Roadie for a ride. It fired right up but as it was warming I noticed it started stuttering and missing. Went for about a block before it got worse so I turned right around. It threw an error code then died in the driveway. No lights, no gauges, no nothing. Pushed it back in the garage and took the 1190.
When I got home hours later it fired back up as normal. It didn't run great but it did fire up then and several times afterward.
When I hooked up TuneEcu it said the error code was P0560 ECM Power Supply, Circuit Malfunction.
What says the collective on the best places to start the trouble shooting?
Battery and charging check out good, connections are tight, no obvious broken wires.
TIA
