Rocket Jan
Standard Bore
2022 Triumph Rocket 3R
Hi, I have a 2022 Rocket 3 R and the warning light came on. After a couple of short rides it disappeared again. I could not see what the fault was and I don't like that much. The check engine light was not on. Would I be able to read a code on the OBD 2 port? Is there a code reader that you can recommend?
I would think that most any automotive OBD2 code reader would work for that, they can be had starting at 25 US dollars. Or you could go to most any national chain auto parts stores, they will hook up their OBD reader and read the codes for free.
Write your reply...
