warp9.9 Pocałuj mnie w dupę Joined Jun 10, 2007 Messages 11,481 Location Forest City Illinois Ride 07 Rocket Jul 18, 2010 #1 check your tps postion and see if you bumped it it should read .6 volts + - .02 volts.
warp9.9 Pocałuj mnie w dupę Joined Jun 10, 2007 Messages 11,481 Location Forest City Illinois Ride 07 Rocket Jul 18, 2010 #2 no you can check her cold it won't effect the tune but it will make the ecu read the wrong tps% line verses what it is in affect raising or lowering the idle.
dieselr3 .020 Over Joined Jul 24, 2007 Messages 19 Jul 26, 2010 #3 Frank just out of interest,after you had the roadster dynoed,with your setup do you notice any glowing from the header pipes at night?
slaphead .060 Over Joined Sep 8, 2009 Messages 103 Location Sunny England Jul 26, 2010 #4 fat frank said: Problem solved. had a problem with the F/L table. Had that corrected and she purrs now. Click to expand... Fat Frank, so what did you do to correct it? Mine has started to show this prob now...I have the same set-up, but rumblers instead of tor's.. Cheers..
lonerider .040 Over Joined Sep 12, 2005 Messages 67 Location Vic Australia Jul 26, 2010 #5 He was another member of Monty Python wasn't he?? Eratic Idle? Did not show up to many episodes was a bit ur ,,,, eratic?
lonerider .040 Over Joined Sep 12, 2005 Messages 67 Location Vic Australia Jul 26, 2010 #6 I,m so proud I,ve finally put a post in the technical side of things! Well, not a very silly walk!
Blastedbones Nitrous Joined May 5, 2007 Messages 1,294 Location Queensland Au. Jul 26, 2010 #7 Templar said: Genius... Click to expand... He made a fortune out of the Spamalot musical...
lonerider .040 Over Joined Sep 12, 2005 Messages 67 Location Vic Australia Jul 27, 2010 #8 Was that Mrs Scum?
