Engine guard install,, heeelp!!
mexican
Tulsa OK
2012 Carpenter Silver BACK240
I started to install the engine guards or crash bars, left side went smooth, right side a big pain, there is a bolt that holds the engine but it just spins, looks like there is a nut behind it somewhere but cant see it, has anybody taken that bolt off and how??
That bolt goes straight through to the other side, you are just spinning the nut on the other side. You must support the motor and take that bolt out.
Just looked at your picture go to the oil tank look at the left of the tank and you will see the end of the long bolt that you will have to remove, put a jack under the engine, the bolt might need a wee tap to get it out but it will come
How hard is it to line the hole up again when the bolt has to go in again? do i have to wedge the engine a little with the jack? is that the only bolt holding that monster engine in place??:eek::eek::eek:
