Emission removal
On the touring it was four.
If you look at the diagram in the other thread you will see that it is one each for #1 and #2, #3 takes two caps. This was taking all of the hoses off. If you trace them out you will see them.
REMOVAL of EVAPORATIVE LOSS CANISTER
bob
Okay removed all the bits in the picture, capped off all TB connections six in all, bike now running rough will run but idols roughly plus have to twist the throttle to start it up, have I removed something I should not have I know all I have to do is put everything back on and it will be fine but I really want rid of those hoses also check engine light staying on even after a five mile run not connected my ecu cable to check it yet.
That looks like more stuff than I took off, now I will have to go look and see where the other hose goes.
Link Removed
bob
Right in that there newly created hole, I placed my Stebel.
Works great!
BTW - I just re-routed pipe B back up to the upper connector on #3 for a closed loop.
NO CODES - all good for 5K miles.
I think you may have removed the hose (one from each TB) that join together at a 4 way plastic cross-shaped connector. The fourth leg of the connector has a slightly wider diameter hose that goes to the manifold air pressure sensor. The 4 way connector can be found, with the tank up, about half way along the frame rail on the right hand side. It would certainly cause the issues you described.
Hope this helps,
Mark
Correct Mark that was the first part that I put back on fired up no problem and the check engine light ran away. Will put the rest of the parts in a box and stash it beside my other stuff
Reactions: MIG
I haven't decided whether to excise mine...it works....and more depends on whether I wish to use the space it occupies for something else.
If I didn't get the occasional sputtering and difficulty to keep running after a fill up when I put too much gas in or filling up in the AM and having it sputter and try to stall for a while on the way home I would have left mine in place also....but those things were enough for me to finally pull it off. I will probably use the space for some electrical doodad pretty soon.
bob
I am in process of removing the fuel evap. canister. New lines and plugs on carbs but what to do with electric hookup on canister? Also installed a RamAir system on the bike and got rid of all that ducting. Made hooking up Triumph spotlights a lot easier.
Bill
I also overfilled on trip last summer, and rather than the engine trying to suck it up, it went to the ground, and everyone though I had a leak. I explained that it would quit dripping when the tank either used some up or we got in a shady area. But, I am going to excise the canister and assorted plumbing too, if for no other reason but to make room for my Suzuki rectifier that is gathering dust on my workbench!
