Disable ABS? (2.5L)
go into rider mode and you should be able to disable it there, but even in sport mode, that front end should come up, i brought it up in 1rst, 2nd and 3rd last week, and i wasn't trying to, it just kind of happened that way, disabling the TC gives you some nice burn outs as well
my bike definitely does not do that!! Also, I see the option in rider mode, but there is no way to “un-check” it. Maybe it’s tied to mileage as a precaution like the previous guy said.... ugh.
The manual indicates that ABS can be disabled. You would maybe have to disable both abs and tc (rider specific mode) to wheelie the bike. And the tc, and most likely abs is a temp setting. It will reset after you shut the bike down. I haven’t looked specifically at this bike, but many use wheel speed for multiple systems. I.e. abs and tc.
Thanks for the reply... I see those screens on the bike... the only item you can not change is the ABS.
Write your reply...
