CRIUSE CONTROL
HELBOY
MOLINE IL
2005 ROCKET SE
:?: I want cruise conntrol on my 05 r3 se. Is adding the audiovox ccs100 the only real option. also should I use a vacuum pump or just a chamber to store vacuum????
CRUISE CONTROL
Thanks for the info on vacuum pump. I also have a HD Fatboy, if I like the R3 with Audiovox ccs100, I will prob install same on the HD. Maybe I should look at the Dakota digital for the HD. What would work best on the HD, it's a 2005 Fatboy with FI. thanks
TDRAGGER
I see your vehicle list. I rode my brand new 1968 Triumph Bonne to the Palwaukee Airport ( Wheeling Il ) back in 68 when I soloed.
I just put the Break Away system on my 08' R3T. It was $200... Really easy to install, and works great.
CRUISE CONTROL
INSTALLED THE AUDIOVOXCSS100 LAST WEEK ON MY O5 RS SE. RODE 100 MILES COULDN'T FIND A HILL THAT CAUSES THIS THING TO KICK OUT. TESTED FROM 35 MPH TO 80 MPH ALL FEATURES SEEM TO WORK AS ADVERSTISED. I USED THE RECOMENDED VACUUM TANK, PLACED IT BEHIND THE TRANNY WHERE THE CAT BOX WOULD BE. NO HEAT PROBLEMS YET.. I LOVE IT... :lol:
I have had the CCS100 on mine for a couple of months with a vac can made of PVC pipe. Have not had a single problem, easy install, I removed my air box for the triple K&Ns so the can location was a no brainer. You cant beat a $100.00 electronic cruise control.
