Clutch Rod Is this the right way around?
El Bruto
.060 Over
Rocket 3 2005/6 modifed!!!!
Well, nearly finished rebuilding engine.. But can decide from manuals if this is right..
It looks like the first design, i would recommend getting the updated stuff as these are a weak point.
Didn't realise these had been updated.. Not going to change anything else now..
I've done the 2nd gear, Detent roller, output shaft bearing..
All I want to know is if these are in the correct order?
Ive just got everything out for Detent replacement, I was confused that I have a different lifter shaft than the one shown in Bennys video for clutch renewal, & I have no small radial roller bearing on the shaft. Mine is an 09 Classic so I thought i'de reply as you asked about it.
The first photo is of my bike, second is a still from Bennys video. Hope it shows the difference, I can't tell if it's the heavy duty shaft or not.
I hope Captain Jack doesn't mind me borrowing this, a picture being worth a thousand words and such.
That looks as if the needle bearing is against the way washer?
