hombre
Nitrous
- Joined
- Dec 31, 2006
- Messages
- 1,021
Regarding the lock-up clutch, I know of 4 supercharged R3 that have snapped lifter shafts now. Let me clarify my experience.
I had to bore my lock-up pressure plate out because Nev sent me the "old style" that would not accept my stock 2006 ball bearing. This was where Nev and Murray discovered Triumph had changed bearing and pressure plate for 2006.
Then I proceeded to fry my bearing and snap my lifter shaft. This was my own fault ("learning experience"). The lesson being: NEVER PULL CLUTCH ON MISSED SHIFTS OVER 7000 RPM!!! I have not experienced any problems since I learned this, but I don't even use the lock-up clutch to upshift. I only use it to downshift, and at stoplights. The adjustment of the clutch is critical. I only use the slightest clutch pressure to downshift... never pull full lever. I only pull full lever at idle... startup and stoplights. I recently inspected my lifter shaft and lifter piece when doing cam work, and this riding technique has kept them looking absolutely new. No wear whatsoever.
I've been asked about my use of a thicker bearing. I don't really know if the use of the thicker bearing is really necessary. I tried it because I was already set up boring the pressure plate. If you do use it, be FN careful to set the deck height on the pressure plate. This is critical, and you will ruin the pressure plate if you get it wrong! The bearing I used is Timken/Fafnir 9103K. I used the standard Triumph lifter shaft and lifter piece part numbers for 2006 models, and as I remember, was sent the re-designed parts.
Also, I would not recommend hardening the lifter shaft. The lifter piece is already hardened, and having 2 hardened parts working on each other would likely lead to failures elsewhere. When you mis-shift or mis-adjust with the lock-up clutch... something has to give. Better to have the simple lifter shaft break than something more critical, deeper inside the engine!!!
Aside from my initial learning experience, I have nothing but good things to say about the lock-up clutch. It handles 250 ft-lbs torque with ease... and I'm still using my original clutch plates from 2006!
