R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,374
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
Something went sideways so when it was disconnected for the bar install.
The lifter shaft has a spring on it to keep it from sitting on the lifter piece / pull rod when clutch lever is out. When the arm that connects the shaft to the cable was taken off, the shaft might have spun out of correct position.
It should be rotated in anticlockwise direction until it wont turn any further, then as you let go you should feel the spring turn it clockwise a little.
The arm gets put on at that point with the dot line up
Then cable connects and free play at lever to be 2-3mm
