wjb
Nitrous
- Joined
- Dec 16, 2019
- Messages
- 1,279
- Location
- California No Longer!
- Ride
- 2008 Rocket III Touring 2002 Bonneville America
Is that full synthetic blood or synthetic blend?
BattleAnd this morning, after a bloody battle, it is even closer yet, bolts in place, and once again, I'm out of gas, done for the day.
Synthetic blood leaks moreIs that full synthetic blood or synthetic blend?
I knew you were CLOSE"Fabricating" slow, but sure. I have to go to the steel shop, and dig through their "drop" box. In no hurry. Kinda watching the storms. S.W. Florida
Ah, a fellow bleeder,my buddy told me that I'm the only guy he knows that manages to bleed paintingAnd this morning, after a bloody battle, it is even closer yet, bolts in place, and once again, I'm out of gas, done for the day.
The main bearing gallyway has lost its prime. You should pull the filter and pour oil down the block fitting then spin the filter back on and fire her up real quick. You might have to do it and pug a plugout of each cylinder and spin her over until you get it primed with oil. Loosen the sensor in the back and watch for pressure. And well go start a thread !!!!!OK, got the 2013/15 (can't remember) engine in my 05 Rocket. Got her fired up, but the oil light stays on ???? Also, after putting in 5 qts of oil, the oil tank is empty ??? I can stick my finger into the oil tank, and nothing ???? WTF ???? HELP !!! Yes, the sensor is connected. Wondering if I need to hook up tune ecu and clear the codes ???
