Cleaning carbon buildups
Run good quality fuel, dont bog the motor down by running low rpms in high gear and you wont have a problem with carbon build up.
Good quality fuels has the detergents added to prevent this.
please can you give couple example of that? like what is low rpm for gears? i think each gear has different low rpm?
Just don't bog down (lug) the motor. Shift down so the RPMs are not too low- you can hear and feel it.
If pressed for a number I'd say don't cruise below 3K, keep it around 3.5 - 4.5K cruising and below the redline for everything else :thumbsup:
