Grendel
.040 Over
(Posted on both the .com and .net sites)
Hey Guys,
I had to put my newly purchased Carpenter Rocket in the shop last Saturday because the check engine light decided it wanted to be my friend. My local Triumph shop is always behind and so my bike has sat there until yesterday before being looked at. When I called yesterday for an update, they told me that they got it up on the rack that morning and their mechanic had worked on it for a couple hours testing different components, but everything was turning up good. He said they are not done testing yet, but they are leaning toward thinking the ECU might be bad.
So if that is the case, how bad is that going to hurt my wallet? Also, they should be able to copy my Carpentered fuel map to the new one no problem, right?
Also, I am not really sure that I trust this shop. They might be 100% on the up and up, but some of what they tell me sounds a little off, but I know nothing mechanically to be able to tell if it actually is. They told me that the wiring on this bike is different than what they normally see and asked if I knew the bike's origin (where it was made). I talked with the original owner and he bought it in New York, but maybe it was manufactured in Canada? Also, they told me that the ECU looked like it was aftermarket and I have an email out to the original owner, but I don't think it is unless Carpenter replaces the ECU when they do their mods.
Finally, and you guys will probably know about this whereas I don't, can't you plug a cable into the ECU and use a diagnostic software to find out what is triggering the check engine light? I know it wouldn't be something that is pin point accurate, but I would expect it to give a good direction like indicating an issue with the fuel line. The mechanic wouldn't know where the issue is in the fuel line, but he would know to focus his search there. Maybe they did that, but it sounded to me like they are doing a point by point process of elimination (at 80.00 an hour!) to go through the whole bike.
I am a bit frustrated and worried and would appreciate your feedback. Thanks guys!
Hey Guys,
