charging system fault
...mechanic said that failed R/R leads to ignition system remaining energised even with key off.
Sorry, but that part is complete nonsense - I'd love to have him show me on the schematic how that 'magic' is possible
I know you're just repeating what you were told ....
However, pleased your system problem is apparently resolved
I'm having issues finding the SH847aa...though at $550+ for the OEM I'm happy to keep looking for the Shindengen!
My next stop is a Suzuki dealer
Replacement was a Shindengen FH020.
My bike has no accessories to draw power - mechanic said that failed R/R leads to ignition system remaining energised even with key off. Apparently common fault with Harley's too. I'm no mechanic but replacing the R/R (and nothing else) did resolve the problem.
Repair cost $349
I've seen those R/R's on ebay for under $40 + delivery....did you get a full receipt with part numbers from the mech who fiixed it for you?
The genuine Shindengen range starts around $180 here in the wild wild west
I've seen those R/R's on ebay for under $40 + delivery ....
Those are not genuine - see my post #7 in this thread
This is the real thing - note the arrangement of the round pillars .....
FH012
FH020
Ripoff #1
No round pillars ......
Ripoff #2
Getting a little more 'clever' - they added the 'pillars' to the heatsink, but note how they are aligned
FH012
FH020
Ripoff #1
Ripoff #2
Indeed...it was a couple of your earlier posts on other threads that prompted my research. I like to believe that even dealerships wouldn't over-charge by a magnitude of 10x actual cost
Ok folks I have a non-charging battery problem.
12.6v across the battery 3 days since bike was last started....so it seems to be holding charge.
While cranking volts dropped to 9 - 10 then steady at 12.3 at idle.
Holding 2000rpm it took about a minute for voltage to rise to 12.9
Had to stop as Mrs Hunt decided it was too hot leaning over the exhaust holding the multimeter probes.
Have removed R/R and completed tests as per the manual and it checks out ok.
From grey connector to engine earth on any of the 3 pins i get open circuit (as opposed to a zero ohm read) and assume this is how it should be??
So my first qu is do i have a failing stator, failing R/R that I've misdiagnosed, or something else entirely?
The bike will run for a few days before the battery is too weak to start it. A few hours trickle charge and she's good to go few more days.
Check this guy out!
Home
Ah I misunderstood your intent
Yes, I would certainly be checking to be sure that is a genuine one, but even then the $349 total is stiff for something that should not even take an hour to diagnose & replace.
Re that seller - Why would you pay $207 USD for a 'kit', most of which is redundant as it already plugs into the OEM wiring?
Partzilla even has this on EBay for $168 (and offers international shipping - although it's a stiff $54 by Priority Mail) -https://www.ebay.com/itm/Suzuki-32800-31J00-RECTIFIER-ASSY-/273474042312
Oddly enough the price directly on their website is $165.04
Wasn't he the owner of the Gem Saloon in Deadwood? :roll: :thumbsup:
@1olbull Nice one! :roll:
Bit subtle for most unless they are familiar with the show.
Watched the new movie version at the weekend - all the original characters (except Powers Boothe, who died) - good storyline and as good as ever was.
Try to check it out if you were fan of the show.
