Has anyone considered having their stock exhaust exchange pipe ceramic coated. We all know that the cats are in the mufflers on the R3T and since I have a completely stock system, performance isn't a big deal. If money was no object I would replace the entire system, but it is, so I am looking for a way to reduce the heat the exchange pipe puts off.
Also, anyone consider having the stock header and exchange pipe ceramic coated?
I sold a bunch of coated pipes at my dealership and NONE of them held up they only lasted one season I had a set of hot rod headers done and the turned to CRAP in no time
Thanks for the photo Paul! @Rocket3Pilot the pipe that the headers go into and mufflers connect to. I believe it balances the exhaust pressure going out both pipes.
Thanks, no I doubt de-cating would reduce heat in that connector/crossover. I just meant the muffler itself doesn't get as hot if you remove the CAT.
If you use Paul's crossover you will be able to eliminate that middle piece and then use either stock mufflers or TOR's. Then later on if you can't suppress the urge for more power, you can add Paul's header.
If you use Paul's crossover you will be able to eliminate that middle piece and then use either stock mufflers of TOR's. Then later on if you can't suppress the urge for more power, you can add Paul's header.
I have talked to Paul about having him create a custom dual pipe w/crossover that would connect to a stock header. Then I can buy a set of headers from him once I've saved a few pennies back up.
