CEL issue and Code help
Tugboat Tim
.040 Over
Houston
08 tour
hi all
this afternoon was looking into a speaker issue and raised the tank on my 2008 R3T --- means I had to disconnect the gauges on tank... any way put it all back together now get a CEL --- so opened tuner and getting code P1690 CAN-BUS connection ---- any ideas what this is? sitting at bike now with laptop so can do lots of quick tries..
hi all
hi all
hi all
I don't disconnect gauges, just flip them forward
If you use the PDF Manual then you can "Control F" to do a search. Enter the CEL code, then hit the "Enter" key, and all will be revealed.
I installed the GI Pro with ATRE and now I have code P1690; when I reset the code, it comes on again. 2014 R3T. I checked all the Gi PRO connections with an ohm meter and re-connected the plug for the tank gages. The bike seems to run fine, just the check engine light is on. It still occurs with the GI PRO in the - off setting or in the 3 setting. Any suggestions?
Not sure if this will help but you may have a indication fault up but no issue (like a residual from unplugging them) Does everything work and the bike start? If so stopping and starting the bike may self clear the fault. I'm not too familiar with CANBUS but we have used it at work a couple of times. It may be unplugging the gauges caused the items address, or number, to be lost temporarily on the BUS it should relink and clear itself.
Not much sorry but all I can offer here
Sorry ignore above just read the first post by Tim as it was at the top and noticed it was form 2014!! My bad.
Thanks anyway Sleeves.
Tomorrow night I may try removing the black/pink wires and connecting them together outside the GI Pro plug, effectively disconnecting the GI Pro and see if the code will reset.
Write your reply...
