Cam shaft questions?
It is time for valves to be checked for clearances. My questions are 1) should I be considering getting some cam shaft mods done? 2) what are my options? 3) what do I need to adjust the valves myself? Thanks
If your cams aren't making a lot of unusual clatter and/or ticking noises at idle (loose valves) and you're not having difficulty starting and/or idling (tight valves), your valves are probably still within spec and don't need inspection/adjustment.
When you are doing the valve clearence, changing cams is a good option.
With stock pistons a 245-250 cam with about 0.35" lift at the intake and stock exhaust cam will do a good job and add about 15hp.
Ask Neville Lush or Carpenter if he has got something for you.
But it takes some experience to fit and adjust it.
Tuning Video Part 2
Write your reply...
