Blew a coolant line
You can use a straight piece of heater hose but one end is smaller than the other and it is a ***** to get at without pulling the front house, pulling the water pump cover also helps. Just finished replacing that exact hose 3 hours ago. Took the dealer a week to get the hose and water pump cover "O" ring which there are 2 different one depending on you bikes serial number.
I missed the Three Twisted Sisters ride because no on had the parts in stock.
I was looking at the Samco kit and one end did look slightly larger than the other. What size heater hose did you use? If you had to estimate, what are the diameters required at each end?
Sorry you had to miss that ride. I've called 6 area dealers and none have the hose in stock.
This has me wondering if it is just a bad batch of hoses that got installed on these bikes or is this bound to happen to us Roadster guys sooner or later?
Mine is an 08, but it does seem to be a common problem across the years
Using precision guesstimation 7/8" one end 1 1/16" other end, I had o split the old hose end to end to get it off. I used a 1" piece of heater hose it was very tight because of setting in the indention in the front of the case, as soon as I got the hose on the dealer called and the correct hose had come in so I pulled the heater hose back off.
My same hose sprung a pin hole size leak last month. Dealer didn't have in stock either. Ordered the Samco Sport hose kit late on a Friday night. Got the confirmation it shipped on Monday and it was here on Tuesday morning.
What website did you order from with such quick delivery?
