Best Tire Size for Handling
There are not many 130s that have the load rating we need. If you ride to limit a 130 could become dangerous when the big beast gets to pushing hard in a corner and loads up that front sidewall. But if you are mature and never loose control you may be ok with a 67 which alot of 130s are. Easier for a 17in than the 16.s, just food for thought on load and speed rating.
Excellent advice. I researched front tire options as I was not happy with the handling on the stock sized Metzler that was on the bike. Based on the advice of some respected members here, I decided to experiment with the 130. I knew that pushing the Big Girl hard through the twisties, especially with my big ass on it , was not an option. I ended up taking the 130 off before its time and installed a 140 Avon Cobra. Pretty happy with it.
I want to try a 140
I want to try a 140
Running on Front:
Avon Cobra Chrome AV91 140/75R-17 ($164 at Rocky Mountain ATV)
Running on rear:
Bridgestone Excedra Max 240 ($160 at Rocky Mountain ATV)
Pretty happy with the combo. I seems to get a better mileage with the Excedra Max rear than the
Metzler, but that's still only about 4K miles (vs 3K for the Metzler).
Running on Front:
Running on rear:
Out of interest, do it look noticeably smaller?
Smaller than the factory tire, but not odd on the bike. See for yourself.
Several guys have tried a 130, none I know of stayed with it. I talked to 1olbull, it does screw up antilock brakes function, too.
"I talked to 1olbull, it does screw up antilock brakes function, too."
Good point. I have a 2005, so no ABS, but yes, I have read where the difference between the stock and the 130 can screw up ABS. From what I have read, it seems that the 140 is less likely to cause ABS issues.
the 140 lowers the bike 1/2 inch in the front. bike stands up more on the stand.
i went into a curve to fast or was not paying attention soo i was leaned over and moving toward the yellow stripes so i muscled it on down till the floor board
was rubbing hard and the front forks started to wobble (real pucker moment) then it just came up and i could breathe:eek:
Stud!
