Best Tire Size for Handling
Your man is ill informed. There is absolutely nothing wrong with mixing tire brands.
The motorcycle manufacturers make deals with tire manufacturers to get the best prices.
i was going through my manual and it says that going non recommended tires can cause ABS to malfunction....did anyone experience that with exedra and road5 setup
I haven't read of any ABS problems with the rear Exedra Max combined with the Michelin Road 5 150/70 front, or any brand of 140/75 front.
Rocket Captains using a 130/80 front DID HAVE issues.
The circumference ratio is close to 8%.
Drop below this and you will get an ABS fault.
Do not go smaller upfront than a 140/75R17 or 150/70R17 and you will be OK. Mine faulted with a 130 front tire.
Do not go smaller upfront then a 140/75R17 or 150/70R17 and you will be OK. Bind faulted with as 130 front tire.
Ohhh....thanks a lot....I just got my tires...would have been so short if I had to return them....looking forward to get them on ASAP....
Is the tire pressure suppose to be same as specified on the bars...34 front and 42 rear for exedra and road5 ?
