Would you please tell me why the cable clutch is what you prefer? I'm really stuck on this one issue, maybe for no reason. It just seems like a bike of this size should have everything more heavy duty.
Thanks, Eric
I'm not the guy who said he preferred the cable, but I will take the bait anyway.
If you can design the clutch control so that it is comfortable to use, there is no inherent advantage to hydraulic over cable actuation.
In fact, the simplicity of the cable is a big plus because you do not have to replace clutch fluid every two years (recommended for hydraulic actuation systems), and there is no possibility of a leak since there is no fluid.
Cables are incredibly reliable, and with proper inspection and maintenance, they give NO trouble. They are cheaper, lighter, less complicated, and simply a more elegant solution to the problem of clutch actuation.
Now if you can't design a cable system that is comfortable to use, then hydraulic would be preferred.
I've had many many many bikes with both. I honestly don't care which one is on any particular bike as long as the clutch is easy to control.
I can unequivocally state that the clutches on the three Rocket III Tourings I have owned have all been very easy to operate, and I have never once thought that Triumph chintzed on the mechanism. It works beautifully.
FWIW, I am a retired mechanical engineer, have been riding for 49+ years, and have owned nearly three dozen motorcycles during that period, from Honda S90 to BMW K1600 GTL. My favorite bikes are the Rocket III Touring, and the BMW K1300S. Rocket has cable. K has hydraulic. Who cares?
