boale
Cape Cod, MA
Those of you running PCV with Autotune how do you have the Autotune configured in the software, ie. Minimum run time, Minimum Engine Temp, etc. Do you also leave the Autotune enabled all the time or turn it off once you get a good tune. Thanks for any help.
I dont have the temp sensor hooked up on mine. It's set to default which is to run for a minute and then start monitoring. I run it continuously.
I got a tune from Hanso that approximates a Wayne Tripp tune. Ask him about it, it runs quite nicely.
I used the factory 60 second setting. I also run the A/T all of the time. Remember,,,,altitude and atmospheric conditions will change how your bike runs on any MAP. The A/T keeps the engine tuned to the MAP no matter where you ride.
