$130 Can for a VC gasket
. I've purchased 2 and they have each been under $40 bucks Can.
When I've replaced mine, I've lifted the tank, removed the plastic covers behind the forks, removed the 2 bolts holding the coils, then disconnected any wiring that would get in the way, removed the Ramair and replaced gasket, properly torquing the bolts. Even with the proper torque, these newer gaskets seem to squeeze out around number 1 on the exhaust side. Had to replace the gasket again last month within a few thousand kilometers of the previous one. These new gaskets are not as durable as the silicone ones I've seen in the automotive world. They tend to tear when compressed and squeegee out of place.
I guess I'd better keep one in stock at home here since they do tend to give you a lot of notice before failing.
