Anyone have H4 HID kit experience on their RIII ?
MileEater
.040 Over
Cupertino
Hi,
Anyone have experience with H4 HID kits? I'm considering installing on my Rocket III.
I've just installed H7/H9 in my Tiger. It's so cheap now. Just wondering how good a dual
mode HID lamp can be...
Thanks
Roy
..I just installed (easy peasy) the headlight relay kit from eastern beaver..made the lights twice as bright..no need for anything else IMO..also installed his double stebel horn relay kit..now I can blow the fkn cell phone right out of their hand..I hooked both kits into his '3 circuit solution' he sells..everything is plug and play..no wire stripping involved..so easy a caveman could do it..
+1 on the eastern beaver H4 kit's but order at least 3 inch longer than the standard one as a bit short to get the relay's under the tank, rkt88 have you got an extra relay on your stebel? or am I reading it wrong :Tip-Hat:
..I've got 2 stebel horns mounted..one on each side of the radiator..they sell a double kit..it's not the nautilus..double magnum I think they're called..the eastern beaver guy sells a particular harness for that particular set up..works well..
..and you're right about ordering longer wiring between the headlight plugs and the relays..that's what I did too..they fit under the tank nicely..
Write your reply...
