mexican
The issue with mine was that when you hit the starter button it just clicked, or maybe turned over once then nothing. It felt more like a dead battery, if it would crank and not start that would be more like the pump, i thinkA french fellow had have the same problem , Mexican !
He thought it was a battery problem as you do .
He got the idea to check the fuel pump . The pressure must
be 3 bars and he got only 1.9 bars . He tested the pressure regulator,
it was ok to 3 bars so he changed the pump and now it's OK .
Perhaps you should test the pressure on the ruber line before the
injectors , with a T on the line and a manometer that would be useful .
