An R+D Thread - Different instruments.
... I do have a complete loom - but it is attached to a brand new boxed set of kmh instruments. I'm reluctant to hack that apart. Maybe his Electric-ness @DEcosse knows what the spec's for said plug are.
I believe it is this one that mates to the one on the Main Harness:
- see page 5-8
Note that the image in the link does not reflect the actual part - see the product drawing (above) for confirmation
The Plug (Female Terminals) is 174047-2 (On the Main Harness) - on Left of drawing above.
The Cap (Male Terminals) is 175652-2 (on Speedo Sub-Harness) - on right of drawing above
Male Terminal Cap:
In US available at Mouser -
(note that you also needs the terminals, available separately)
In Europe from RS - https://uk.rs-online.com/web/p/pcb-connector-housings/5306319/
Here are some Interconnect Diagrams I created:
(note interestingly that although there is a wire in the Main Harness Connector for the Illumination, it is unused on the Speedo Sub-Harness that I have on-hand)
It is VERY IMPORTANT to note that the OEM speedo put OUT a switched 12V on Pin 18 (B/Y) which is REQUIRED to drive the speed Sender - when installing an after-market Speedo Cluster this B/Y MUST be connected to a switched 12V source (i.e. connect it to Ignition Power since your after-market gauge will not have this provision)
See also these threads for more on the subject
Potential Replacement for failed instruments on Classics
Instrument Replacement
I received a sub-harness from @Rocket Scientist along with a 'failed' set of Original Instruments to take a look to see if there was anything I could find:
Original analysis didn't show anything obvious on the board and without a schematic I was unable to do much real 'active' analysis;
However when I pulled out the harness to create the diagrams above, I did see this .............
^That is the one that mates to the main harness - NOT PRETTY!!
(on the mating side, the terminals looked clean however - interestingly there was evidence of dielectric grease on the mating side, but not the wire side)
I'm not sure if that had any bearing on the failure mode - I did not notice it when testing out the module.
I suspect not because I know instrument replacement has resolved this issue (and presumably the original sub-harness was re-used)
Whether or not it contributed to the instrument hard-failure remains open however ............
I will try to clean it up and re-test the module I have to see if it makes difference (again, suspect it won't - my power connections were clipped directly to the wires via positaps )
Don't forget, if you need it, the wiring diagram is in my signature.
OK - Here's an important-ish note.
GET AN INSTRUMENT THAT HAS DECENT DOCUMENTATION.
This cheepo off ebay is a bit lacking. For example it says it will switch kmh/mph but does not say how - not exactly.
And the wiring colours are all over the place - no winging it, or something will smoke.
For example (reading between the lines) the speedo sensor supplied operates at 5V
I will eventually need to measure the voltage on wire "speedo out"
I will be initially testing WITHOUT connecting to the bike. When I know it all works - stage 2 begins.
This could be a while. Right now I lose dexterity after about an hour in the workshop (it's a bit too chilly still).
Speedo calibration will be a PITA with this cheepo as it does NOT have a self-teaching mode.
But the rolling circumference of the rear tyre needs to be input - plus the pulses per wheel revolution which (iirc @warp9.9 ) is 48 ticks.
@scot in exile - Take a browse at Motorcycle Gauges - not by any means the cheapest - but Jon only stocks what he believes in.
It might give you some ideas - Digital/analog - sizes etc. I would personally NOT go for ACEWELL - I have seen a few fail.
It's (nominal) 12V (might measure bit less but nominally that's the supply, NOT 5V)
This is amazing info to have. I bought my ‘05 last fall knowing the speedo was bad and have been waiting to order a new one, not knowing if I wanted to stay OE or aftermarket.
