Alternative starter motor, in Aus.......
Cheers Pete, maybe it was Hanso that was fitting one he sourced?
Mine starts fairly slowly so i figured that the faster spin would be good.
Oz,
I was going to do that, but the single wire connection to the solenoid would not reach with the motor housing and brushes fitted up.
The wire exits at a different rotation point to the original.
Now I know why Pedro had me buy one take the motor off and ship it to him in Perth. I tossed the rest in the bin
Warp, that would be why.
That would be a lot cheaper, i imagine.
Would you be willing to do the same again?
If so, let me know the total cost, plus a bottle of whatever you chose for your trouble.
Don't the specs help identify a match here in Oz - take this info to Repco or your auto elctrician and they should find a match easy.
New Starter 1999 TOYOTA SOLARA 2.2L
Description
This starter fits the following:
Replaces:
DENSO FIRST TIME FIT
280-0174
LUCAS ELECTRICAL EUROPE
LRS01659
NIPPONDENSO
228000-6170,
228000-6172, 228000-6173, 228000-6280,
228000-6281, 228000-6282, 228000-6283
TOYOTA
28100-03100, 28100-74260
OEM(s): Denso, Toyota
Type: OSGR
Voltage: 12 Volts
kW: 1.4 kW
Rotation:CCW
Teeth/Splines: 13 Teeth/Splines
Pinion/Splines OD:40.4mm / 1.591in
Mounting Hole 1: 11.0mm ID Unthreaded
Mounting Hole 2: 11.0mm ID Unthreaded
Approximate Weight: 8.9 lbs / 4.05 kg
Ill give it a go, but when i mention i am after something that i can fit to a motorcycle most seem to have a little fit.
I may have an old school Auto elec that might help.
Price:
US $62.00
Approximately AU $89.68
Postage:
US $80.00 (approx. AU $115.72) USPS Priority Mail International Medium Flat Rate Box | See details
Add 10% GST for Intl eBay and 4.2% currency conversion and it is Au$235.43
STARTER MOTOR DENSO(17774)LEXUS ES300 3.0L,1998-2001 RX300 1999-2003 VIN 1MZFE | eBay
starter denso
LEXUS
1998 ES300 3.0L, VIN 1MZFE
1999 ES300 3.0L, VIN 1MZFE
2000 ES300 3.0L, VIN 1MZFE
2001 ES300 3.0L, VIN 1MZFE
1999 RX300 3.0L, VIN 1MZFE
2000 RX300 3.0L, VIN 1MZFE
2001 RX300 3.0L, VIN 1MZFE
2002 RX300 3.0L, VIN 1MZFE
2003 RX300 3.0L, VIN 1MZFE
TOYOTA
1998 AVALON 3.0L, VIN 1MZFE
1999 AVALON 3.0L, VIN 1MZFE
2000 AVALON 3.0L, VIN 1MZFE
2001 AVALON 3.0L, VIN 1MZFE
2002 AVALON 3.0L, VIN 1MZFE
2003 AVALON 3.0L, VIN 1MZFE
2004 AVALON 3.0L, VIN 1MZFE
1998 CAMRY 2.2L, VIN 5SNFE, Opt HD or Cold Weather
1999 CAMRY 2.2L, VIN 5SNFE, Opt HD or Cold Weather
2000 CAMRY 2.2L, VIN 5SNFE, Opt HD or Cold Weather
2001 CAMRY 2.2L, VIN 5SNFE, Opt HD or Cold Weather
2002 CAMRY 2.4L, VIN 2AZFE
2003 CAMRY 2.4L, VIN 2AZFE
1998 CAMRY 3.0L, VIN 1MZFE
1999 CAMRY 3.0L, VIN 1MZFE
2000 CAMRY 3.0L, VIN 1MZFE
2001 CAMRY 3.0L, VIN 1MZFE
2002 CAMRY 3.0L, VIN 1MZFE
2003 CAMRY 3.0L, VIN 1MZFE
2004 CAMRY 3.0L, VIN 1MZFE
2005 CAMRY 3.0L, VIN 1MZFE
2001 HIGHLANDER 2.4L, VIN 2AZFE
2002 HIGHLANDER 2.4L, VIN 2AZFE
2003 HIGHLANDER 2.4L, VIN 2AZFE
2001 HIGHLANDER 3.0L, VIN 1MZFE
2002 HIGHLANDER 3.0L, VIN 1MZFE
2003 HIGHLANDER 3.0L, VIN 1MZFE
2001 RAV4 2.0L, VIN 1AZFE, Opt 1.4kW
2002 RAV4 2.0L, VIN 1AZFE, Opt 1.4kW
2003 RAV4 2.0L, VIN 1AZFE, Opt 1.4kW
2004 RAV4 2.4L, VIN 2AZFE, Opt 1.4kW
2005 RAV4 2.4L, VIN 2AZFE, Opt 1.4kW
1998 SIENNA 3.0L, VIN 1MZFE
1999 SIENNA 3.0L, VIN 1MZFE
2000 SIENNA 3.0L, VIN 1MZFE
2001 SIENNA 3.0L, VIN 1MZFE
2002 SIENNA 3.0L, VIN 1MZFE
1999 SOLARA 2.2L, VIN 5SFE
2000 SOLARA 2.2L, VIN 5SFE
2001 SOLARA 2.2L, VIN 5SFE
2002 SOLARA 2.4L, VIN 2AZFE
2003 SOLARA 2.4L, VIN 2AZFE
1999 SOLARA 3.0L, VIN 1MZFE
2000 SOLARA 3.0L, VIN 1MZFE
2001 SOLARA 3.0L, VIN 1MZFE
2002 SOLARA 3.0L, VIN 1MZFE
2003 SOLARA 3.0L, VIN 1MZFE
Replaces:
280-0174
LRS01659
NIPPONDENSO
228000-6170,
TOYOTA
