Oh give it time , there is nothing you can do that's not been done by someone else here , and there is nothing you can do that money can't fix ! :thumbsup: except maybe upset @Steel ? :D
Yep it's hard to upset me. Had a bad temper when I was younger, but I've worked hard to find peace, and won't give it up easily. ;)
Hey Rick, everything i've ever read on this forum re: K&N is "the bigger, the better' as far as breathing goes. do you run it like that without a claw, or have you cut the claw out? Or do those fit under the claw?
With my RamAir I've cut the claw to expose it to more air.
Link Removed
I'm thinking if I switch to K&N I'll go with the bigger ones since they should have room with the cutout.
I also think I could use a 3/4" or so, hole saw to put a hole in the claw somewhere in the top-front area then install a PCV grommet, slip the AIT sensor thu & cap it with the small filter so it sits right outside the claw in the same line of air with the T/B filters
Whata ya'll think?
I experimented every which way with that little AIT . Inside , outside and up side down ! Some methods worked better than others but all had drawbacks when the engine was either cold or hot . Tal and Ricks positioning is definitely the best , however I still had problems when the engine was hot . By opening the end of the little filter and fitting the fine gauze , the sensor can now keep a few degrees cooler . Starting from hot or cold is instant and idle is an absolute constant no matter what the temp !
Will be doing the same next weekend. Be prepared for a bit of bleating and comments of 'how d'you do this'...etc
Don't want to hijack the thread -- my missus has made tea for me several times a day since before we were married 26 years ago - much of that loose tea using - you guessed it - a tea strainer.
Tea available to anyone who visits. :)
I'm definitely a girl and could not live without it, but I am tea strainer virgin , maybe she can teach me ;):D
Hey cobber, there is no need for them fancy strainers if you have a moustache! Just sayin';):eek::D
It is becoming a fad for tea fanciers! ;)
Women with moustache
But for the un-endowed - you can always go true blue and share my cultural cringe right through (spoiler alert) to the very painful end!
I think this bloke took Russell Coight under his wing at an early age!;):D
Write your reply...
