AIT location
if you look closely you can see the # 1 K&N under the bear claw.
I posted a pic of the bear claw installed on Starmanuts post.
Don't know about the touring but I do know I had a very similar problem with the bear claw pushing the foam and damaging it . I was going to stick a price of self adhesive foil to the contact patch on the filter but not sure if that would have worked ? I've gone with the KnNs and whatever issues they bring with them . We Rocket owners it seems , do love a fiddle !
I have already dismantled Tayas stainless steel tea strainer giving me a 3 inch diameter of very fine mesh . I'm on it ! Will let you know the results .
...oh i know what the result will be!!!...5 stiches under your right eye for pinching her tea strainer!!! but if it works then its worth the trouble right?
All this talk of the RamAir falling to bits is getting me worried. Mine is now 2 years old but looks fine. Now, should I swap for the K&N solution? But I like the bear claw in its entirety so would have to be the smaller ones - RU2780's??
I have had the RU-2780s on my R3R since spring of 2015 without an issue, the bear claw fits perfectly over the filters.
I too had Ramair on my 2014 Roadster. When ifitted it i over tightened the hose clips and broke one of the rubber collars that goes over the throttle bodies...under the hoseclip.
I eventually decided to go the k&n way and had my bearclaw cut away and purchased the RU2780's. I got my engineer friend to make aluminium inserts to fit the recess in the top of the filters and araldited them in after polishing them up.
They look and work just fine and because you can wash them and reuse them over and over they will last.
sounds to me like the k&n filters are the way to go over the ram air couple folks here said the ram air have come apart
But why just a few - incorrect or accidental exposure to solvents of any kind would not help.
Also using incorrect filter oil seems a likely cause as RamAir do NOT use regular K&N or Uni filter oil but a NON oil substance they sell in service kits.
With a lifetime guarantee to purchasers from RamAir , it is very likely a case of not following service instructions or exposure to contaminants. Otherwise make a claim.
RAMAIR Air Box Elimination Performance Air Filter Kit for Triumph Rocket III 3 | Ramair Filters
If you want a cheaper option to K&N pods there are these RamAir ones.
Price:
GBP 18.68
Approximately AU $34.72
Approximately US $24.44
Buy It Now-
RAMAIR Universal Performance - Performance Race Foam Pod Air Filter 62mm ID 689854616553 | eBay
Item Specifics
  • Part Number - MR-011
  • Number of Filters - 1
  • Neck Inside Diameter - 62mm
  • Filter Shape - Cylinder
  • Neck Position - Central
  • Outer Diameter - 92mm
  • Filter Height - 100mm
  • Filter Material - Foam Body / Polymer Neck
  • Worm Drive Clamp - Included
For motorcycles we have a series of 'pod' style air filters designed to clamp onto the engine air intake(s). These allow maximum air flow at all times. Comes with clip for attachment.
All of our foam pod filters come with a lifetime single user guarantee against manufacturing defects.
Image is for illustration, you are purchasing a single filter with the specified dimensions.
We have spent years designing the optimum intake/induction filter kits for fast road and high performance use.
Pod Filter Features
  • High Performance Twin layer foam
  • Hand made here in the United Kingdom
  • Easy to clean using hot soapy water
  • Stainless steel clamp included
  • Guaranteed surface area using high quality custom blended polymer
  • 100% Hand made in the UK - Guaranteed against manufacturing defects for life
  • Long lasting and hard wearing
Or these MAYBE IF you used offset extension connectors Front and rear up and center down. See following post with TB dimensions.
Price:
GBP 34.99
Approximately AU $65.04
Ramair Universal Cone Filter With Aluminum Base - 63Mm Od Neck - 150Mm Wide 5056185604163 | eBay
Part Number: JS-150-63-BK
This filter is designed to be inserted into a flexible hose such as a rubber or silicone intake pipe.
These filters have an aluminium ram-pipe neck and a cone shaped filter element. This integral cone channels all the incoming air, towards the inlet manifold, and in doing so, reduces unnecessary turbulence. These filters are also cone shaped because it enables easy fitting to space restricted engine compartments and with the extremely large amount of foam surface area an added boost of power to your engine too!
The filter is specially strengthened using a stainless steel internal mesh, which we have developed & used in european and world touring cars!
With its large size, technologically advanced filter and bell mouth alloy spun base this filter kit is capable of handling extremely large power & flow rates.
Key Dimensions
  • Neck Outside Diameter (A): 63mm
  • Overall Width (B): 150mm
  • Overall Length: 200mm
Component Dimensions
  • Base Width: 150mm
  • Base Length: 65mm
  • Filter Top Width (D): 115mm
  • Filter Base Width: 150mm
  • Filter Length (C): 135mm
Item Specifics
  • Base Material: Aluminium
  • Base Finish: Powder Coat
  • Base Colour: Black
  • Filter Material: 15mm Dual Layer Foam
  • Filter Reinforcement: Stainless Steel Mesh
