Aftermarket led turnsignals
I saw 200€ and out off stock and they fit under the fender I did not like how it looks! Side mount is easy cut your stock live the bracket on 3 holes swingarm mounting points add pice off aluminum tig weld it for 60$ and make holes in new plate and screwed new bolts with stock plastic cover or by 35$ eBay special bracket with small light and you golden! Another 20-30$ for powder coating in winter time ;)
My cousin powdercoats AND welds...i may have to pay him a visit!
Yep I in love with this new set up , can not get enough of it
Replaced my Wunderkind with Analog Motorsports. Slightly smaller, slightly brighter.
Did you get the Wunderkind turn signals shipped to the USA? I tried to order a set but they do not include the US in their shipping drop down window. Even e-mailed them with no response.
I think with any set of aftermarket LED turn signals rocket looks much better then stock towers;) I like both , what about rear??
What all was required in making these work, and what did you do for the rear
My front and rear are the same! No resistor required direct swap plus solder your stock turn signals connectors! Rear fender needs to be disassembled from bike to make identical holes for turn signals and rerouted wiring from swing arm to under the tail and all wiring must be stripped from isolation to cut Black wire from junction and solder in almost near the plug to live side license plate light on swing arm!! Or live the license plate under taillight and you don’t need to mess with wires at all just rerouted all harness under seat!! It looks and sounds a lot off work but actually it’s cut one wire off isolate, same wire but in he opposite side open isolation and solder one new black wire and solder black new wire which you extend with black wire on plug for license plate!! One place cut two places solder and new wire protection or electrical tape. Rear turn signals same plugs but red tape market from factory Right side, without Left side, square plug is LP light
The Analog doesn't seem to fit the shape of the Triumph rubber mounting piece. Does it need adjusting to match mounting piece or is it not shaped like the mounting piece end? The Wunderkind seems to fit right.
