Aside from an oil change just what does the 600 mile service consist of. I have 540 mileson mine and will be needing one as soon as all the snow melts... Brrrr :D
There is a list of "check/adjust" items. It just gives the tech the opportunity to go over the bike to make sure nothing is loose and things are properly adjusted.
Thanks... I found my little book that lists the items to do. I will do it myself. The book says to use 10-40 motorcycle oil. Any brand recomendations?
I use Mobil 1 4T 5W30
I prefer thinner oil that lubricates the upper end quicker on start-ups.
I chump for the Royal Purople max cycle 10 40. It's gone up from 12.00 a quart to 17.99. Still beats that $300.00 plus oil change. I can assure you that is all they did. If you do it yourself, you need to check all of the bolts you can reach. Some tend to vibrate loose.
later
service
i think i paid $380 for the standard service here in oz at my dealer and i got my 16000k service not long ago wich is the valve clearence one and it was $720 wich i feel is absolutly rediculous and as u might notice our dollar is about even with the US dollar at the moment i feel we here in oz are just getting robbed for everything probably has alot to do with our tax system i would imagin . our government is one step away from just following u around and going through your wallet whenever they like bastards:mad:
same here
Same with Canada, its all B.S
Our dollar is now the same value (at par) with the U.S dollar but our prices for everything are much higher.
I order a lot of stuff online now from the U.S its cheaper.
A good example is a new Roadster here in Canada is $16,999
but the exact same one across the border is $13999.
