Okay....so here is my comment and question. My shaft splines were not lubed at my first rear tire change at 7K. I'm sure the guy I had swap the tire out didn't do this. I plan to do this at the next tire change as I will be jacking up and removing the tire myself this time. In looking at the service manual, it looks like I have to remove the rear shock bolt and the 4 other acorn nuts to remove the bevel box to allow access to the driveshaft spline. My question is...once this is done, does the whole drive shaft pull out so you can access both ends or not? Are we talking about just lubricating the bevel box end of the shaft or somehow doing both ends? Does the shaft somehow receive lubrication where it attaches at the engine? The manual addresses the specifics about making sure you insert the axle shaft before tightening and torquing the bevel box bolts , but I don't see much as to whether the drive shaft pulls out. Are there any pitfalls I should be aware of when lubing or more specifically assembling the drive shaft back on the bevel box? This will be on the touring model, not the roadster.[/QUOTE
You will be ok easy job, I just did mine for the first time. Watch for the spring on the end of the spline shaft, I put some grease on it to hold it in place. Just cock the bevel box up on a angle and wiggle back and forth quickly and it will slide right on. Also don't forget to clean and re grease the hub gear, use high quality high temp bearing grease. I used this. Good luck.
