210K carpenter map
danny42
Standard Bore
rocket 3 classic
Is there proven map for download for triumph rocket 3 with carpenter racing 210kit and carpenter street road exhaust and ram air....i have that setup would like to flash ecu and remove PC5...
just thinking wouldn't it be better to ask carpenter
The Carpenter ECU maps are like 90% of the way there, the power commander is used to dial it in for the individual bike.
You can of course import the trims from the final PC map into the Carpenter ECU map and then remove the need for the PC to be on the bike. Of course the trims don't move across properly and it take a few goes and adjustments ime.
The Carpenter ECU maps were always TuneBoy but a few years ago they were manually grafted over into TuneECU maps to massively improve accessibility for folks.
There are a few on here in the resources section.
tune boy they only use to unlock rev limiter....(200usd) my bike revs to 9176rpm now with 210Kit...what's gonna happen when you flash ecu directly and remove pc5? , rev limit stays same like I have right now...9176rpm..
