leigh_m_gardner
Well the RedRocker has almost exceeded 18,000 miles so will soon be needing a 20K service. A lot of miles have been put on in the past few weeks, so checking the service workshop manual, ive placed a few orders for parts....
2 x Triumph Oil filters = £15 from local dealer
From Opie Oils where I get a bit of a discount:
12litres (enough for 2 bikes filter/oil change) of Castrol Power 1 GPS 10w40 semi-synth = £58.39
6litres (enough for 2 bikes having a coolant flush) of Motul INUGEL EXPERT ready-2-use coolant = £22.22
I am having difficulty finding the final drive (gearbox) oil specified in the workshop manual "MOBILUBE SHC 95/W 90 FULLY SYNTH" - anyone got any ideas where I can get it or an alternative?
Also, will need replacement crush washers for the drain plugs. I will ask at the local dealers when I go get the 2 oil filters but does anyone else have any ideas of a supplier?
Apart from the engine/gearbox/coolant changes - the air filter needs replacing, but im going to run K&Ns on both bikes so dont need to bother replacing that at the moment.
The headstock bearings need checking and greasing - but since im putting the new black forks/yokes on the custom bike - I will be putting the current ones off the custom rocket on the red one, so can check and grease at that time.
Anything else needed doing? Fuel filter?
