2025 Rocket 3 HP to Weight Ratio
DesertRat
For those interested;
The 2025 R3 Storm Weight to Horse Power Ratio, (using published factory specs) compared to a common U.S. V-8 powered Muscle Car.
2025 R3 Storm
Weight - 317kg s 2.2 = 697.4 lbs
HP = 180hp
Formula
HP /Weight = HP to Weight Ratio
180/697.4 = .258hp/lb
Compared to a 2025 Chev. Camaro ZL1 1LE rated at 650Hp @ 2870lb = .168hp/lb
Enjoy
Using your methodolgy my Speed Triple RS comes out to .343 hp/lb based on the last dyno measurement at the rear wheel. Based on factory spec numbers that changes to .411hp/lb. That's not a true value either since you must include rider weight as well to be accurate. Curb weight of the Z1 Camaro is listed as 3,907 lbs, so again your numbers are a bit off. Suffice to say that until you get into true exotic automobiles, bikes have an edge.
