2020 Triumph Rocket 3 Fender Eliminator
Got her done and bent the plate
Done! Hit a wheelie, bent the plate on the tire, go figure
Looks like you need some adjusting. Haven't hit mine and I did compress the suspension to make sure I had enough clearence.
Hit a hard dip and preload was only at 2 turned it up to 5. Using the taillight as the LP light plenty bright. I have a good angel on the plate and it's tucked under the taillight far enough to make it bright. The tag light that came with the bracket mounted made the plate drop about a 1" more. Watch out for full compression on the rear(heavy hit or dip) it will hit
Should keep stones and sh*t from taking the shine off the tail light lens too...
and...you can get led lights/bolts which hold the plate on too....just look like bolts with a led light in the head and of course wires.
Don't need them unless inspection a hole says different (whit light,red light BS)
This is fully compressed. The mount is real close but the plate has plenty of room.
